Got a rattle - Page 7 - BMW S1000RR Forums: BMW Sportbike Forum
Old 09-02-2012, 04:26 AM   #61 (permalink)
DynDuo's Avatar
Another rattler here. I have an '11 model work full exhaust, HP levers, etc. I personally think it's something below my windscreen, because if I press on it from the outside-in, it stops. Like some of you, it only happens when the exhaust rumbles and it's very annoying. I had HID's and put the regular bulbs back in due to fuse issues and BMW recommendation. The issue was there and still is. Very annoying.
DynDuo is offline   Reply With Quote
Old 09-02-2012, 11:23 AM   #62 (permalink)
luker669's Avatar
Originally Posted by Dean s1000rr View Post
Great find I think that's my rattle too. Did you or can you upload the vid on how to fix this. I'm not too great with tools so it'd be helpful for me to see what you did so I can follow it step by step. Thank you luker669
I didn't make a video of the fix , I had made a video of me shaking it when it was off and you can hear the rattle but the video didn't record any sound.
luker669 is online now   Reply With Quote
Old 09-05-2012, 09:26 PM   #63 (permalink)
Great thread, I wish I found it earlier. I have the exact same rattle. I took off all my plastics, windscreen, horn, and headlight housings. From there I rode up in down a country road in 2nd with my throttlemeister locked at 5800 rpm's. Finally after a few minutes, I was able to find that the rattle was coming from that black key lock box. To verify your bike's rattle problem too, just squeeze the black box (finger on the top and bottom) behind the key and the noise stops.
Thanks for your help Luker669, now I just need to apply your fix!
-Jay
Sent from my iPad using MO Free
jchatn is offline   Reply With Quote
Old 09-05-2012, 10:07 PM   #64 (permalink)
DynDuo's Avatar
Thanks, everyone. I never thought of using my throttlemeister.
Old 09-05-2012, 10:29 PM   #65 (permalink)
luker669's Avatar
I've done 1000 miles since the fix ,still no rattle
Old 09-06-2012, 02:21 AM   #66 (permalink)
DynDuo's Avatar
Good news!
Old 09-06-2012, 03:05 PM   #67 (permalink)
Okay I finally found my rattle..looks like a ball sack hanging from the filler cap.. here's a pic
Sent from my SCH-I535 using Motorcycle.com Free App
SS1000RR is online now   Reply With Quote
Old 09-06-2012, 03:19 PM   #68 (permalink)
Originally Posted by 3blueS1000rr View Post
I`m one that HATES rattles...
I had an interesting one and hard to pin point as it only could be heard at about the same revs as you...4-6k ..
Inside the tank was the location, in there it has a bob/lever weight that swings about freely which comes in to play when your bike gets dropped and it shuts off the fuel to the pump by closing a needle valve (safety cut out for fuel)..
It can easily be taken out and solved, the weight swivels on a small pin with small washers and the washers wear down thru use, all i did was removed the pin,washers and weight and squeezed the pin mounting lugs in very slightly which takes up the slap on the sideways movement of the weight (which was the cause of the rattle)......
Also if you have this rattle it can be heard more easily if your tank is less full as it echos more...and if you remove your tank and empty the fuel and shake the tank from side to side you will hear the rattle..
Probably not the source for your rattle but worth posting...or put in a sticky (if the forum has one for faults)?
Good luck
You were right my friend.
Old 12-12-2012, 12:07 AM   #69 (permalink)
vmaster's Avatar
Originally Posted by luker669 View Post
here is a pic of the lock ,the 2 lower pins in the pic are roll pins that hold the steel housing around the locking pin this also was loose and rattled , tapped those in also and flared the ends so it wouldn't back out. Test ride was perfect no rattle ...I'm happy again
I'll try that, thanks.
Vladimir
vmaster is offline   Reply With Quote
Old 12-12-2012, 12:09 AM   #70 (permalink)
vmaster's Avatar
That wasn't my rattle 😞
Vladimir
