Performance question re: "burning rubber" - BMW S1000RR Forums: BMW Sportbike Forum
Old 01-25-2012, 06:51 PM   #1 (permalink)
Cool Performance question re: "burning rubber"
My 2012 doesn't get in til next week so I am left to live vicariously through you guys...haha. I am going crazy waiting. Anyway just curious...my question is, will the S1000RR turn the rear tire over just by applying throttle from a rolling start? For example you leave a red light at normal acceleration, can you just roll the throttle and will the back tire break loose? No clutch involved? My H2-750 would do that way back in the day, but my FJ1100 with yoshimura exhaust back in the late 80's would not. I also had a '92 Nissan 300Z twin turbo that would roll the tires just by pressing the go pedal from a rolling start....so will the S1RR do that?
Old 01-25-2012, 07:24 PM   #2 (permalink)
If you crack on the throttle you are gonna point it straight up!
Old 01-25-2012, 07:31 PM   #3 (permalink)
without clutch hmm im with war eagle on this...Try it and let us no what happened
GregSKRR is offline   Reply With Quote
Old 01-25-2012, 07:38 PM   #4 (permalink)
sbs
sbs's Avatar
NO.... Not unless the road surface is slippery or similar. Even with cold tires, you won't get wheelspin with traction control on.
If you are in "slick" mode, then yes.. I have had wheelspin in 5th gear while accelerating in a straight line.
sbs is online now   Reply With Quote
Old 01-25-2012, 08:19 PM   #5 (permalink)
pimpedc6's Avatar
You will not get any unmanageable wheelspin from a stop unless you crack on it with TC off from a dead stop. There isnt much power below 5k rpm. If you are worried about too much power down low then put it in rain mode. Even in race mode from a dead stop you really have it hit it hard to get unmanageable wheelspin. TC really tames things down in the wheelspin department.
2007 R1, Pazzo Levers, -1 front sprocket, Full Ohlins suspension, Grave Block off plates, Akrapovic mid pipe, Yashimura exhaust, Stomp grip tank pads, Puig windshield, Bazzaz ZFI and AFM, BMC Race filter.
2011 BMW S1000RR with ABS, TC, and Race Assist. BMW Akrapovic Slip on exhaust, Stomp tank Pads, Puig Windscreen, Frame Sliders and Fender eliminator
Old 01-25-2012, 08:20 PM   #6 (permalink)
pimpedc6's Avatar
Oh an i have ridden power wheelies on wet roads. These things have good traction when using good tires.
Old 01-25-2012, 09:13 PM   #7 (permalink)
Not worried about it being uncontrollable just wondering if the bike will do it with the big sticky tires...DTC in slick mode I mean...in other words I want to feel the rear end break loose on throttle roll...guess I will find out soon enough...sounds like the answer is no on a dry road...my H2 had 70's era skinny tires but it sure was fun to hang the rear end out when you wanted to...ala motocross bikes, except on pavement.
Old 01-25-2012, 09:19 PM   #8 (permalink)
AMPforE's Avatar
I seriously doubt it, not because of not having enough power, but because the tire will stay hooked up. Plus, to break the tire loose like that you would need a snap in power which a hard roll on will not give you. Now, stand up, lean a little bit forward putting more weight on the front tire, and clutch it up and I don't think you will have a problem spinning the tire.
1991 Suzuki Bandit 400
1996 Kawasaki ZX6
2006 Triumph Speed Triple
2009 Honda CBR1000RR ABS
2010 BMW S1000RR
ABS-DTC-Shift Assist
Fastest Color Motorsport
Old 01-25-2012, 09:30 PM   #9 (permalink)
Thanks....that was what I suspected given the tire technology on the new(er) bikes...not only did my H2 have skinny bias ply tires, it was also a two stroke which had a crazy power curve, it started htting hard at about 4,000 or 5,000 rpm with the redline at only around 8,500 on my bike....plus I weighed all of 135 lbs back then, which didn't hurt the cause.
Old 01-25-2012, 09:43 PM   #10 (permalink)
GhastlyTT's Avatar
I know for a fact cracking the throttle in race mode on cold tires will spin the rear up. I accidently did it last week leaving my house. Caught me way off guard. If it wasn't for my dirt bike days, i probably would've dropped my shiny bike
GhastlyTT is offline   Reply With Quote
