Need new grips - recommendations? - BMW S1000RR Forums: BMW Sportbike Forum
Old 01-15-2012, 07:33 PM   #1 (permalink)
Default Need new grips - recommendations?
I ride hard and do a lot of track days.
Thx
Old 01-15-2012, 07:46 PM   #2 (permalink)
jwxfd's Avatar
Send a message via Yahoo to jwxfd
I've always had good success with pro-grip grips...
jwxfd is offline   Reply With Quote
Old 01-15-2012, 08:03 PM   #3 (permalink)
AMPforE's Avatar
It makes no difference what grips you decided to use, your real questions should be how do I get the stock grips off?
1991 Suzuki Bandit 400
1996 Kawasaki ZX6
2006 Triumph Speed Triple
2009 Honda CBR1000RR ABS
2010 BMW S1000RR
ABS-DTC-Shift Assist
Fastest Color Motorsport
Old 01-15-2012, 11:59 PM   #4 (permalink)
S&Kmotorrad's Avatar
yeah, as i replaced the clip on over the weekend, that stock grip puzzled me too...
I end up using the stock grip for my new clip on...LOL....
S&K Motorrad
Live2Ryde
2011 S1000RR
2009 K1300S
Old 01-16-2012, 07:56 AM   #5 (permalink)
RC51Player's Avatar
Hate to admit it but, I have a stock grip on the left bar and a different grip on my quickturn throttle. I would love to change it out. Somebody must know a trick. The compressed air trick that I've always used didn't seem to work.
Old 01-16-2012, 10:49 AM   #6 (permalink)
V8M3's Avatar
Yeah, I ruined a throttle tube trying to get the grip off. I am back to stock. Very annoying!
Old 01-16-2012, 10:54 AM   #7 (permalink)
AMPforE's Avatar
Do a search. You will find what you are you need. Basically, you have to cut the stock grips down to the tubes without cutting through the tube. This has to be done on both sides.
During the middle of me taking off the throttle side I actually looked up the price of a new grip only to find that it was over $100. At that point I was re-motivated to getting it off.
Good luck.
1996 Kawasaki ZX6
2010 BMW S1000RR
Old 01-16-2012, 11:01 AM   #8 (permalink)
R1HOOLIGAN's Avatar
Both sides have the plastic throttle tube, so only a throttle side grip will fit the left side.....meaning you have to buy two sets of grips. To get the oem grips off, I used a razor blade to carefully cut a slit down the full length of the grip. I then took a pair of forceps and clamped down on the edge and "rolled" the grip off like the top of a sardine can. Just took my time and used the razor blade to cut at the stubborn points.
I installed Driven Gel Grips.
Good luck with your project.
Current Garage Inhabitants:
2010 S1000RR - White/Blue/Red
2008 Honda CBR 1000RR
2008 Kawasaki ZX-10R
2006 Suzuki GSXR 1000
2008 Suzuki M-109R LE
2008 Kawasaki Teryx
R1HOOLIGAN is offline   Reply With Quote
Old 01-16-2012, 12:08 PM   #9 (permalink)
RC51Player's Avatar
Thanks for the heads up. I hate to have to buy 2 sets of quality grips to have one useful set and 2 pieces of trash. But you gotta do what you gotta do. And its easier then when I had to take the dermal to my OEM throttle housing so I could attach the switch cluster back on the right clipon.
Old 01-16-2012, 02:52 PM   #10 (permalink)
DrIoannis's Avatar
Get rid the left plastic tube and use only one pair.
