I don't think it's a very big job, access is fairly easy, the tough part is the glacial response of BMW au 7weeks. You should be better, hopefully, shipping the part was the slowest bit. It showed up as a throttle position sensor fault on the gs911, I found that if you cycled the key 10 -15 times it would get it working again. Although this must of cleared the fault log in the ecu, because the dealer said there were not faults logged. It's a tough one, once the bike is cold it'll start OK and clear the error log, so you need them to look at the log without attempting to start the bike once the problem has occurred.
