Interesting reading from Powerlet:
Calculating Excess Electrical Capacity - Learning Center - Powerlet Products
I know my Gerbing's full-heated suit has a 15 amp inline fuse in it. The dual controller is supposedly a pulse-duty cycle which should draw fewer amps. I know on the other BMW bike group that BMW has some liner that was design for their Can-Bus bikes that tripped the auto-breaker at 5 amps so they made their jacket for those. It was only an amp or two lower than the Gerbing liner. I know on my GT, the jacket only got luke-warm as the Can-Bus throttled it on and off so it really never got hot.
I looked in the S manual and didn't see the output spec's for the bike. I think it has a 40 amp main fuse though so maybe 400 watts max (I'd guess more like 380 maybe?). If the Powerlet data says 285 watts to run the fuel injected things (I found the fuel filter drawing twice the watts if plugged interesting: 60 to 120 watts!) you should have 100 watts to play with. I run some extras like a GPS, Autocom, and radar unit so I don't know how much extra I have already in my actual numbers so I may be under 100 watts for my reserve (hence the stingy Warm-and-Safe liner at 60 watts and their gloves at maybe 25 watts?).
Aside.
Here is a photo of one of my Gerbing jacket liners (I got several, plus defunct Widder gear, plus Warm-and-Safe the most recent.) where I had to replace a failed plug on the road. The thing started getting very hot at the connection and more than the jacket itself. It finally melted. Too much flexing of the wires at the connection led to the break (maybe) and it generated more heat at the break or thin spot than the wires in the liner. Their gear seems to be either made in China or the USA. My Cascades Extreme 4 season heated suit of theirs was Chinese made and the Velcro pulled loose in the first week from bad stitching quality. They took 2-3 months to fix it with repeated calls and the fix was something a 6 year old on a machine could have done (and maybe it was?). I thought they would have just exchanged it as it was new. Wait to fix it took me through the riding season.
Point being is if you have thin spot anywhere in your charging system and pulling a lot of current through it, bad stuff can happen. That's what takes the stator windings and connections going to them down in most bikes.
Mack
