Originally Posted by ereinders
Do you have to replace grips when installing them or can you use the stock BMW grips?
BMW mounts the clutch grip on a plastic tube like the throttle side, so no issues moving them over to the helibars. Which is good if you're happy with the stock grips, because getting the grips off those tubes is a huge PITA, especially on the throttle side. Most of us have practically had to grind them off.
There are several long helibar threads on this forum.
