Main Beam / Flasher failed
Since swapping my bars for the AC Schnitzer flat bars, I can't switch to main beam and the flasher doesn't work. I have stripped the switch down, and can't see anything out of place or damaged, all the wires appear to be intact.
As my bike was due for its first annual service, I asked my dealer to check it out, but they just came back and said I need a new switch, not on warranty as I must have broken it.
Does anyone have a wiring diagram for the bike that shows which wire to the legt hand switch assembly does what?
Does anyone have a second hand switch assembly for sale?
Anyone else had this problem?
The switch seems flakey, as when I put it back together, nothing on the LHS worked, took it off, everything worked, put it back again, everything (except the flasher switch) works again..
Could it be that the switch requirs an earth return via the bars?
Thanks for any info.
Rob
