Originally Posted by martins
I´m looking for a compact system to set the bead.
It might work, but is an awfully expensive and troublesome way to set beads after changing tires. And one tire in five will be difficult to get an initial seal or will require a higher pressure than possible with cartridges to get a bead to do the final pop, so it won't work reliably anyway.
If you're going to change tires at home, you need a compressor. If you're worried about field punctures, there is almost never any need set beads - you plug and go, and in this case, you can use CO2 or a small air pump - personally, I prefer a small pump as you occasionally get a circumstance where you have to replug or have a residual slow leak and with CO2 you only get a chance or two to get a good seal and get you to the next town. But CO2 is definitely compact.
If you're changing tires in the field, you're at someplace with compressed air anyway.
