Ohlins damper - BMW S1000RR Forums: BMW Sportbike Forum
Old 11-29-2011, 05:10 PM   #1 (permalink)
Default Ohlins damper
I am waiting on new damper that I ordered last week. I am curious about what I need to do in regards to installation. Does fairing need to be removed or can it be installed from underneath by removing fender and plastic guard above it? I'd appreciate help from someone who has installed one.
Sent from my Motorcycle iPad app
Cwschramm is offline   Reply With Quote
Old 11-29-2011, 05:34 PM   #2 (permalink)
The damper is a very easy and fast install. Just work from underneath. If I remember correctly, there is only 1 small plastic plate you will need to remove. In fairness, I did remove my front fender so there was no chance of scratching it.
Good luck. A great upgrade you will feel immediately.
jchatn is offline   Reply With Quote
Old 11-29-2011, 06:02 PM   #3 (permalink)
Godzilla's Avatar
Correct, just the one plastic plate to remove. Mud guard is easy to remove if you wish to avoid scratching.
Old 11-29-2011, 06:26 PM   #4 (permalink)
Thanks for the input. That was what I was hoping to hear
Old 11-30-2011, 10:25 AM   #5 (permalink)
im in the same boat as you. mine is laying on the kitchen counter.
what are the torque specs for the dampner attaching to the fork leg.
and then to the frame.
ragweed316 is offline   Reply With Quote
Old 11-30-2011, 11:07 AM   #6 (permalink)
What is the reason you guys are replacing the OEM unit?
Are you really getting that much headshake and/or tankslappers?
I could perhaps see doing so if you were primarily tracking or racing the bike; not so much for the street. The OEM unit seems to work fine for me there...
Old 11-30-2011, 02:54 PM   #7 (permalink)
I replaced mine because i had a bad, almost lost it moment when i had my 848, didnt come with a unit. put on an ohlins, it saved my but a few times
now i wont ride hard without an ohlins unit on it.
the stock is good im sure, but its not great. and after going through what i did on the duck. 300 bucks well spent to switch it out.
Old 11-30-2011, 05:29 PM   #8 (permalink)
HOG SLYR's Avatar
Originally Posted by ragweed316 View Post
what are the torque specs for the dampner attaching to the fork leg.and then to the frame.
Damper to frame - 19nm or 14ft lbs
Damper to fork - The stock bolt is 8mm which torques the same as the damper to frame but the Ohlins uses a 6mm bolt, I used 8ft lbs
The damper mounting clamp screws are 6nm or 4.4ft lbs or 53in lbs.
2011 BMW S1000RR
2005 Honda ST1300a
HOG SLYR is online now   Reply With Quote
Old 12-01-2011, 01:54 AM   #9 (permalink)
Site Sponsor
Don't have to be on the track to get head shake. I like the adjustability of the ohlins.
I can get a deal on a new one for anyone.
Want the Best Price?
Motowheels.com and I are here to get your S1000RR Forum Member Pricing on anything and everything your heart desires...
We are the US distributors of OZ wheels, Dainese, and Oberon. We have a warehouse full on inventory.
Check us out and let me know what you need.
PM or Email me : AdamMoto@MotoWheels.com
Old 12-01-2011, 09:04 PM   #10 (permalink)
easy install
great adjustability,and high quality piece
wont ride without one
canadian mike is offline   Reply With Quote
