Sprockets not the same on HP4 - BMW S1000RR Forums: BMW Sportbike Forum
post #1 of 57 (permalink) Old 12-24-2012, 04:59 PM Thread Starter
At least on the standard. The bolt pattern in the first pic is an aftermarket 520 sprocket off of a 2011 S1K. The second is one for Marchesini wheels from Driven. Although the second one is the same bolt pattern, the holes aren't the same. The bolts in the HP4 carrier are larger (I removed one and tried it). So we get to wait for those to come out too...
ID:	11061   Click image for larger version
Name:	march sprocket.jpg
HP4, std
Cage: 04 Cayenne TT
the head is offline
post #2 of 57 (permalink) Old 12-24-2012, 05:23 PM
Can you further clarify? I'm not understanding completely... it almost sounds like you are saying the bolt patterns are different on the HP4 from the standard S1. But then you compare the HP4 to a Marchesini (which could have a different carrier anyway).
I'm prolly just missing something?!
__________________________
Thank you - 2016 Race Sponsors (click below)!!
Riders Discount**MRRF-Road Racing Forum**Schuberth Helmets**Held Gloves/Leathers**Woodcraft**MOTUL
1000RR is offline
post #3 of 57 (permalink) Old 12-24-2012, 07:57 PM Thread Starter
The HP4 rear sprocket bolt pattern is not the same as the S1000RR. That's the bottom line.
The first pic shows the carrier/hub off the HP4 with a sprocket that fits the S1000RR.
The second pic shows the same HP4 rear carrier/hub with a sprocket that fits Marchesini wheels. It has the same bolt pattern/circle. However, the bolt holes on the Marchesini sprocket are too small (not the bolt pattern).
Hopefully that clarifies it.
I will also say (additionally) that the HP4 carrier/hub looks a lot like the one off my last Marchesini wheel off another bike. The cush drives are also similar between them.
HP4, std
Cage: 04 Cayenne TT
the head is offline
post #4 of 57 (permalink) Old 12-24-2012, 09:44 PM
Jackson's Avatar
Makes me think the Wheels are Marchesini.
04 R1
08 CBR1000RR
13 HP4 Comp
Jackson is offline
post #5 of 57 (permalink) Old 12-24-2012, 11:15 PM
mmmpowr's Avatar
I would agree since the HP4 has Brembo brakes and components. And Brembo owns Marchesini.
'13 BMW HP4 #0296
'04 Yamaha R1 (Sold)
'01 BMW M3
'98 BMW 528i
mmmpowr is offline
post #6 of 57 (permalink) Old 12-25-2012, 12:31 AM
mmmpowr's Avatar
The BMW press materials does describe the HP4 as have a new lighter sprocket carrier.
"New finely wrought 7-spoke wheels in forged light alloy and a new, lighter sprocket carrier give the HP4 a weight reduction of 2.4 kg as compared to the RR."
'13 BMW HP4 #0296
'01 BMW M3
'98 BMW 528i
mmmpowr is offline
post #7 of 57 (permalink) Old 12-25-2012, 02:16 AM
M GmbH's Avatar
The HP4 must use a M10x1.5mm studs like the S1k. Just about everything out there uses M10x1.25mm. That kind of sucks.
M GmbH is offline
post #8 of 57 (permalink) Old 12-25-2012, 11:23 AM
Jackson's Avatar
1.5 vs 1.25 pitch would have no overall effect of the diameter of the fastener. The sprocket would still fit on a carrier with M10x1.25 vs M10x1.5 if the bolt pattern was the same.
Merry Christmas.
04 R1
08 CBR1000RR
13 HP4 Comp
Jackson is offline
post #9 of 57 (permalink) Old 12-25-2012, 12:02 PM
M GmbH's Avatar
You can't put a sprocket with a 1.25 bolt hole on a 1.5mm. That's like putting a pinky ring on your thumb.
Merry Christmas.
M GmbH is offline
post #10 of 57 (permalink) Old 12-25-2012, 01:06 PM
Jackson's Avatar
It's all thread pitch, 1.25 means there is a thread every 1.25mm and 1.5 means there is a thread every 1.5 mm. It has nothing to do with the hole. Also the 10.9 you see stamped on the stud end indicates the grade of the fastener.
04 R1
08 CBR1000RR
13 HP4 Comp
Jackson is offline
Human Verification
