Sprockets not the same on HP4 - Page 2 - BMW S1000RR Forums: BMW Sportbike Forum
Go Back   BMW S1000RR Forums: BMW Sportbike Forum > General BMW S1000RR Discussions > BMW HP4 General Discussion
Old 12-25-2012, 01:23 PM   #11 (permalink)
Your right. It's a M12x1.5mm.
It's was 2am.
Originally Posted by Jackson View Post
It's all thread pitch, 1.25 means there is a thread every 1.25mm and 1.5 means there is a thread every 1.5 mm. It has nothing to do with the hole. Also the 10.9 you see stamped on the stud end indicates the grade of the fastener.
M GmbH is online now   Reply With Quote
Old 12-25-2012, 01:45 PM   #12 (permalink)
Jackson's Avatar
What were you doing up at 2 am? ARE YOU SANTA?
04 R1
08 CBR1000RR
13 HP4 Comp
Jackson is offline   Reply With Quote
Old 12-25-2012, 03:07 PM   #13 (permalink)
No not Santa, but I was working on my naughty list.
Old 12-26-2012, 05:45 AM   #14 (permalink)
Godzilla's Avatar
The OEM wheels on HP4 are PVM not Marchesini.
Old 12-26-2012, 11:25 AM   #15 (permalink)
Jackson's Avatar
I've heard that before, but I don't see a PVM 7 spoke on the market in this desgn, I see a Marchesini 7 spoke; although it is slightly different then the HP4s. I do see what looks like a germany stamp on my HP4's wheel which would probably suggest PVM. Any real proof of them being PVM?
04 R1
08 CBR1000RR
13 HP4 Comp
Old 12-27-2012, 09:00 AM   #16 (permalink)
Godzilla's Avatar
http://www.harris-performance.com/ac...o_PVM_BMW.html
Old 12-27-2012, 10:00 AM   #17 (permalink)
Thing is, even the PVM sprockets use a 10mm bolt. The bolt pattern is the same as the Marchesini/BST. The center hole is a different diameter (just looking at specs) though. So we're still stuck with stock until someone creates something new, as far as I can tell.
HP4, std
Cage: 04 Cayenne TT
the head is offline   Reply With Quote
Old 12-27-2012, 11:15 AM   #18 (permalink)
Jackson's Avatar
I see em, but there are only 6 spokes not 7.
04 R1
08 CBR1000RR
13 HP4 Comp
Old 02-03-2013, 01:14 PM   #19 (permalink)
Rush66crp's Avatar
Did we ever figure this out?? I need a 520 rear sprocket for my HP4!
Rush66crp is offline   Reply With Quote
Old 02-03-2013, 01:43 PM   #20 (permalink)
The stock wheels on my 2010 have a rear sprocket designed for these wheels, when I switched to OZ wheels it required the use of a sprocket to use on these wheels, it came from Driven since the mounting points use a different configuration. I also switched wheels on my 03 Ducati 999R from stock Marchisini, to mag Marchisini's, these too required changing the sprocket carrier, even tho they are made by the same company. Just the way it is. Fran
NotAgain is offline   Reply With Quote
