Originally Posted by moman
YEP! Grew up in Virgil, NY. Small world.
Connect your GS-911 and go into the remove rev limiter section. It should show the mileage that you can remove it at. If you are over 312 I bet you are good to go.
You were spot ON!..
Only issue was at first when I went to remove the limiter the GS-911 didnt want to accept my VIN (first time using it) - I'd go to add the VIN but every time it would show 0 VINs and ask me again- do I want to add one.
So I backed out. Went to the section to set the Date for the bike.
It again asked me if i wanted to use one of my 10 allowable VIN usages.
I said yes add and IT DID add the VIN here.
So then I went back to Engine section and removed the Rev Limiter - No issues!!
So now I'm free to REV- Thanks MOMAN!
312 miles is the magical number!
