Originally Posted by Twisted1
Ok.. I pulled my seat off.
Its a Yuasa YTZ7S for the brand / size.
And..... Drum roll please....... It says electrolyte filled.
So there you go. Lead acid.
It is not a Lythium ion.
I bet a 10 amp/hr lythium weigh less and give us more cca.
Ok I just ordered a Shorai Lithium battery -LFX09L2-BS12
I went with a 9 vs a 7 to get a few more CCA 135 vs 102
battery dimensions are the same- Lenght 4.45in, Width 2.28in, Height 3.5in
Weight for the 9 is 1.27lbs
Weight for the 7 is 1.06lbs
Weight of the stock is around 4.5lbs per Yuasa site, so not a huge savings, but it all adds up.
The length on the Shorai is slightly bigger than ours... 4.25 vs 4.45 so might need to cut a bit on the base of the box in the bike... I'll see when it arrives.
