02-11-2011, 11:18 PM
Site Sponsor
$299 scorpio sri900r alarm
$299 shipped in 48 states
SCORPIO SR-I900 ALARM SRI900 900 RF REMOTE SRI900R
SR-i900
COMES WITH PERIMETER SENSOR, REMOTE IGNITION DISABLE AND BUILT IN BATTERY BACK UP
The all new SR-i900 introduces the next step in motorcycle security by incorporating the convenience of hand free operation to an ultra-compact 2 way FM paging security system designed specifically for the motorcycle industry.
By incorporating RFID to the system is able to know when the remote is walking close to the bike and when its not, allowing the user to never have to reach for the remote to protect the bike.
By utilizing High Frequency FM technology, the SR-i900 transceiver is capable of sending and receiving commands from up to ˝ Mile away from the motorcycle.
For its sensing mechanism, the SR-i900 utilizes a built in accelerometer that detects both impact and changes of angles with a high degree of accuracy. It allows the module to be placed in any position or mounting angle and requires no adjustments.
The SR-i900 control module also offers a built in programmable multi tone siren and to ensure durability the module is manufactured to meet OEM specs
For simple installation the SR-i900 offers optional factory style connector kits that simply plug into the motorcycle’s factory wiring harness creating a non-destructive installation.
tom@biohazardcycles.com
Email me with any questions or deals...
ARROW, LEOVINCE, AKRAPOVIC, TAYLORMADE, TERMI, M4, BROCKS, MUZZY, JARDINE, YOSHIMURA, TWO BROS, ALPINESTARS, SCOPRIO ALARMS
www.biohazardcycles.com
02-12-2011, 12:22 AM
Does the wiring harness actually just plug into the BMW harness, no splices required? Or is this just hype? Where does it tie into the harness?
If this is as advertised, I like what I hear.
02-12-2011, 08:11 AM
Last I checked when I called Scorpio is that you need to splice and they will "likely" never get the plug in due to the CanBus system
02-12-2011, 08:29 AM
Site Sponsor
Nope they still dont make a harness but it only need to be spliced into the blinker wires and connected to the battery..
02-12-2011, 10:58 AM
It is not because it is CAN BUS but because the BMW gets their connectors from Tyco and they are not offered anywhere. We can't even get them at the BMW shop. We can get quite a few but not all.
You need to splice in on the rear turn signals and an ignition "hot" lead so that the alarm turns off when you key on the ignition. And power and ground go to the battery as well but those aren't spliced.
I have the 800 model--no pager. Make sure you get the "proximity" sensor. No problems with mine so far. Had to change the battery in the FOB once so far but that is it. Works great. Install is not too difficult. I put mine to the right side of the subframe rail. Leaves room under the passenger seat and keeps it out of plain sight and a little more difficult to get to for a thief.
02-12-2011, 04:50 PM
Not that i want to go back and forth but that doesn't make sense. Connectors are FREQUENTLY custom made to adapt to different components. Also this is what scorpio said specifically.
03-03-2011, 03:52 PM
plug and play
I emailed Scorpio about OEM connector for S1000 and here is their reply:
"We are working on that connector now. Depending on the production time of the connectors and availability of components, it may be available anywhere from 3 weeks to 2 months."
Thank you.
Aritronix Ltd
03-03-2011, 08:09 PM
Thank you.
Aritronix Ltd
Thank goodness!
I hope they figure this out ASAP!
A friend in Need is a pain in the a**
05-04-2011, 01:03 PM
Scorpio SRi-800
I have read a lot of comments about the install of the 900 alarm but not much about the quality. I recently installed the 800 on my bike and I am not impressed at all. The worst part of this alarm which I think is the same as the 900 is the siren. It is way too quiet. I had a DEI alarm on my last bike and it was way louder. Due to the siren alone I would not recommend these alarms. The second most disappointing thing about this alarm is the RFID. With the remote in my pocket, standing next to the bike, putting the remote and antenna about 6 inches away from each other I have still had the alarm go off on me. Luckily as said before, the alarm is very quiet so it was not that annoying. The third thing that is horrible with this alarm is the perimeter sensor. Sometimes it goes off when you are 4 feet away and sometimes it will not go off if I am waiving my hand over it. There really isn't any fine tuning it because the detection varies so much. The only positive thing I can say for this alarm is that the install was very easy. I had it installed in less than a half an hour. I assume that since both alarms appear to use the same perimeter sensor and siren that the issues are common to both units.
05-04-2011, 01:33 PM
Site Sponsor
thats the first negative comment ive seen on them!
maybe its the 800 model..
ive sold about 500 900 models and never had one complaint
and only about 50 800 models..
did you contact scorpio their support is really good
Toll Free: 1-800-428-0440
International: (480) 951-1109
FAX: (480) 951-1157
16055 N Dial Blvd.
Suite #B-10
Scottsdale, Arizona 85260
Email: sales@aritronix.com
Support: support@aritronix.com
